Hello to all I wanted to ask if there is a way to convert a Rhino-block into a mesh in grasshopper?
Hi
You would need to extract the geometry inside it mesh it and make it a block again
I would recommend elefront to deal with blocks
Or maybe now rhino 8 can deal with that
If you post a definition its easier to help
Rhino 8 looks like this. It has built in components for Blocks and Instances. This one takes a single blocks and converts it to the component meshes.
thanks
thanks a lot
that is good out ![]()
