My inserted control points on a surface are causing creasing instead of smooth surface editing.
Hello- on a degree 1 surface inserting control points will not ‘smooth’ things - rather ChangeDegree to say 3 in each direction. then insert control points if you still need more.
That did the trick. Thank you!
