Hello!
Does anyone know why my surfaces edges are shaped instead of smooth when I use the edit points? Its never happened before…
Thank you
You’ve created a surface that’s degree 1 with more than one control point in U/V. Try using the rebuild command - keep the points the same (5X3) but change your degree to 4 and 2 respectively.
Thank you!!
