Adding control points
Hi all. I have a very basic problem.
I’m having a problem with adding control points to a curve in that when they’re added, they don’t produce a curve but rather a sharp point.
I’m likely just missing something very obvious but haven’t had any luck with online tutorials. Any help greatly appreciated.
08%20AM
if you use Insert control point or Insert knot shouldn’t be a problem. that behavior is when you use Insert kink
