There are some way to cut the contour, made by a polyline, of a image?
Thanks
Thanks
I’m not sure I understand what you are asking. Can you explain further. Sometimes pictures and geometry can be helpful. Are you using RhinoCommon or C++?
Sorry, I try to explain better
I need create a object and apply the texture from the shape defined by a polyline applied to an image.
I have managed create an object with the contour defined by the polyline, but I like apply the texture of the image.
For example, in the next image, I’ve selected the shape, but I don’t know get the image’s texture inside the polyline
I’m working with RhinoCommon and Visual Studio 10
Somebody knows if I can do it?
@andy, any suggestions?
andy…any idea?
Is it a flat polyline?
Else PlanarSrf and properties>material>color use your image?
I need get the image’s texture delimited by the polyline.
I don’t understand that you want say
In order for us to answer SDK question, we need to know how you do this just using Rhino. If you are not sure how to do this just using Rhino, then I suggest re-posting this under the “Rhino for Windows” category. Once you have a workflow, then we can begin to help with providing an SDK solution.
Oki
Thanks
Anyone know how to do this
Well… I need Trim the two objects, but I don’t know how to do it
Any idea?
RhinoCommon does not have a way of creating a picture frame. You could always create a planar surface and then add a bitmap texture to it. Once created, create a polyline on the surface, extrude, and then use Rhino.Geometry.Brep.Split.
I’ve got exactly the same question.
Now I know how to insert a PictureFrame (it was added since the conversation started):
Dim MyPictureFrameID As Guid = doc.Objects.AddPictureFrame(plane, dialog.FileName, False, myImage.Size.Width, myImage.Size.Height, True, True)
But I dont get how to trim the pictureframe with a rectangle? (with rhinocommon)
It works with the “trim” command in rhino.
Thanks for helping
Regards
Hi Matthieu,
A PictureFrame is just a surface. Thus, you’ll need to trim it just like you would any other surface.
– Dale
Hi, I’m trying to do this but it does not work. Somehow I can’t seem to cast the picture frame as a surface (MyPictureSurf is always Nothing):
'check version
If RhinoApp.Version.Major <= 5 And RhinoApp.Version.Minor < 11 Then
Rhino.RhinoApp.WriteLine("ERROR: This command requires at least Rhino5 SR11")
Return Result.Failure
End If
'Pick image
Dim dialog As New OpenFileDialog()
dialog.Filter = "Image Files|*.bmp;*.gif;*.jpg;*.jpeg;*.pcx;*.png;*.tif;*.tiff"
dialog.Title = "Select deck image"
Dim rc As DialogResult = dialog.ShowDialog()
If rc <> DialogResult.OK Then
Return Result.Cancel
End If
'Read image size
Dim myImage As Image = Image.FromFile(dialog.FileName)
Dim p0 As New Point3d(0, 0, 0)
Dim p1 As New Point3d(myImage.Size.Width, 0, 0)
Dim p3 As New Point3d(0, myImage.Size.Height, 0)
Dim plane As Plane = New Rhino.Geometry.Plane(p0, p1, p3)
'add the pictureframe
Dim MyPictureFrameObj As RhinoObject = doc.Objects.Find(MyPictureFrameID)
Dim MyPictureSurf As Rhino.Geometry.Surface = TryCast(MyPictureFrameObj.Geometry, Rhino.Geometry.Surface)
doc.Views.Redraw()
'Pick the cutting rectangle
Dim corners As Point3d()
Dim res As Result = Rhino.Input.RhinoGet.GetRectangle(corners)
If res <> Result.Success Then
Return res
End If
Dim CuttingPt0 As Point3d = corners(0)
Dim CuttingPt1 As Point3d = corners(1)
Dim CuttingPt3 As Point3d = corners(3)
Dim CuttingPt2 As New Point3d(CuttingPt1.X, CuttingPt3.Y, 0)
Dim TrimmingRect As New Rhino.Geometry.Rectangle3d(plane, CuttingPt0, CuttingPt2)
doc.Objects.AddPolyline(TrimmingRect.ToPolyline)
doc.Views.Redraw()
'trim the pictureframe
Dim u0, u2, v0, v2 As Double
MyPictureSurf.ClosestPoint(CuttingPt0, u0, v0)
MyPictureSurf.ClosestPoint(CuttingPt2, u2, v2)
Dim u As New Rhino.Geometry.Interval(u0, u2)
Dim v As New Rhino.Geometry.Interval(v0, v2)
MyPictureSurf.Trim(u, v)
doc.Views.Redraw()
Hi Matthieu,
Try casting as a Rhino.Geometry.Brep.
– Dale
Ok, casting as Rhino.Geometry.Brep works but how do I trim a Brep with a closed polyline?
I just want to do the same as the trim command in rhino, but I couldn’t find any example on the web.
I tried to trim with plans created from my rectangle but it doesn’t work and it does not feel to be the best way to do this anyway:
MyPictureSurf.Trim(New Plane(CuttingPt0, CuttingPt1, New Point3d(CuttingPt0.X, CuttingPt0.Y, CuttingPt0.Z + 100)), 0.2)
