No, there isn’t a method to trim a Brep with a curve. In this case, try extruding the curve so it intersects the Brep. Then, use Brep.Trim
Hi, I tried as you said but the Brep.trim gives me an brep without image:
'Pick image
Dim dialog As New OpenFileDialog()
dialog.Filter = "Image Files|*.bmp;*.gif;*.jpg;*.jpeg;*.pcx;*.png;*.tif;*.tiff"
dialog.Title = "Select deck image"
Dim rc As DialogResult = dialog.ShowDialog()
If rc <> DialogResult.OK Then
Return Result.Cancel
End If
'Read image size
Dim myImage As Image = Image.FromFile(dialog.FileName)
Dim p0 As New Point3d(0, 0, 0)
Dim p1 As New Point3d(myImage.Size.Width, 0, 0)
Dim p3 As New Point3d(0, myImage.Size.Height, 0)
Dim plane As Plane = New Rhino.Geometry.Plane(p0, p1, p3)
'add the pictureframe
Dim MyPictureFrameID As Guid = doc.Objects.AddPictureFrame(plane, dialog.FileName, False, myImage.Size.Width, myImage.Size.Height, True, True)
Dim MyPictureFrameObj As RhinoObject = doc.Objects.Find(MyPictureFrameID)
Dim MyPictureBrep As Rhino.Geometry.Brep = TryCast(MyPictureFrameObj.Geometry, Rhino.Geometry.Brep)
doc.Views.Redraw()
'ask for rotate?
''Scale the picture Frame
'MyPictureFrameObj.Geometry.Transform(Geometry.Transform.Scale(p0, 1))
'doc.Views.Redraw()
'Pick the cutting rectangle
Dim corners As Point3d()
Dim res As Result = Rhino.Input.RhinoGet.GetRectangle(corners)
If res <> Result.Success Then
Return res
End If
Dim CuttingPt0 As Point3d = corners(0)
Dim CuttingPt1 As Point3d = corners(1)
Dim CuttingPt3 As Point3d = corners(3)
Dim CuttingPt2 As New Point3d(CuttingPt1.X, CuttingPt3.Y, 0)
Dim TrimmingRect As New Rhino.Geometry.Rectangle3d(plane, CuttingPt0, CuttingPt2)
'Create the trimming Brep
Dim TrimmingBrep As Brep = Extrusion.Create(TrimmingRect.ToNurbsCurve.DuplicateCurve(), 100, False).ToBrep
TrimmingBrep.Translate(0, 0, -50)
Dim TrimmingBrepId As Guid = doc.Objects.AddBrep(TrimmingBrep)
'trim the pictureframe
doc.Objects.Add(MyPictureBrep.Trim(TrimmingBrep, 0.001)(0))
'remove the trimming surface
doc.Objects.Delete(TrimmingBrepId, True)
doc.Views.Redraw()
This add a new Brep
to the document. But where is the original object’s attributes, which contain the material, texture mapping, etc?
Try passing the original object’s Attributes
to ObjectTable.Add
You might use ObjectTable.Replace
instead.
– Dale
Hi Dale,
Thank you so much for your help this is perfect!
