I’m trying to use a Contour command where the direction would be specified by the normal of the curve.
Here magenta contours are representing what I want to achieve. I managed to did that all the way around but essencially I would like to be able to modify the number/distance of those ribs.
I defined all of the normals of the curve tho I don’t know how to apply it to the Contour command (simply connecting the results doesn’t do the trick).
