Hi Kiwi!3D Team,
I am having trouble connecting a shell-element to a rectangular beam. Is there a proper way of doing this? I tried to specify the coupling features, but it didn’t work. Do I have to specify the connection somehow to make it work?
Thanks!
Hey Gunnar,
Could you provide your file? The connection should be detected automatically. Internally, the intersection function of Rhino is used. So you could also test this by looking at the result of the Brep-Curve intersection component. If this also fails, you may find a solution by remodeling it. But I can also have a look at it.
