Connect 2 curves with lines (expert Lvl)
hi guys,
I try to connect 2 closed curves with lines.
The way I need this to be build is to have one curve divided based on a function (with the graph mapper) and its points connected the most vertically as possible to the next curve.
Curve closest point give me this kind of issues…
connect_tow_curves.gh (14.7 KB)
I
ve tried many things… this is not easy…
regards,
-CC
almost got it, that corner is causing trouble. Maybe you can find some solution :frowning:
connect_tow_curves_RE.gh (19.1 KB)
Hi @Jakinta,
I know ! I also tried this plane|intersection methode, but their is always one corner which is wrong…
it is definitly a good problem ^^ …
A bit messy but it might be a solution…
connect_tow_curves_RE_2.gh (30.1 KB)
thank you @Jakinta ! So as i understand its a sort of patch up at places where there is no lines ? Interesting !
I do have a series of curves like this to weave (15) … with multiple branches it willl be a nightmare though :S !
-CC
Yes it is patching up…
Here is a solution with more control of subcurve where there are no intersections.
connect_tow_curves_RE_3.gh (35.0 KB)
Nice @jakinta ! Ill start form here, and now try to apply this for a set of 15 curves… I don’t know if ill be able to deal with one layer deeper of data tree structure…
thanks btw :wink:
-CC
