Hello there, in many years of using Rhino I still wonder how the environment panel works.
The Background colour is useless, it changes nothing. Why is it there?
Clicking Background image, this should open a new box but no. It gives me some nice parameters like multiplier (exactly the same parameter as intensity in the prevoius dialog box).
Say you want to switch to 3 colour background, as in R6? It must be out of fashion.
Say I want to have 2 colour gradient, there is no way of doing it. Am I missing something?
Hi David thanks for your reply, I still have confusion.
If I want to see reflections on the object without changing the environment, do I use
Backdrop / Use custom environment for reflections? Or set it under object or material properties?
You can also create a custom environment, or for this example, use a built-in Rhino one.
This example uses the Rhino8 Sunset for the 360-degree envrionment, what you see in background. The reflections however come from the Rhino internal BCN Airport, which is preloaded, at least with Rhino 8.
If I edit the environment Type from Basic Environment to HDR or bitmat, there seems to be no way of going back to basic environment. Am I correct? Browsing shows different folders every time.
With a brand new computer this environment thing is very laggy and random, I’m frustrated.
