I forgot how do you light a scene using a certain environment, but make the environment disappear? Can someone please remind me?
Thanks,
Thomas
Thanks,
Thomas
In the Rendering panel under Background set one of solid or gradient color. Make sure that further down under Lighting you have Skylight checked along with Use custom environment for skylighting, set to the environment you want to use for lighting.
Wow! Perfect instructions! Many thanks. One more question; where do you rotate the environment? In Render Panel, or Environment Panel?
Kindly,
thomas
Easiest is probably through the Environment panel.
Got it,
Thanks again,
Thomas
