ComputeVertexColors fails on this mesh
This mesh has texture colors which display correctly, but ComputeVertexColors doesn’t work: afterward when inspected in Grasshopper/DeconstructMesh there are no colors.
If I export as .ply with vertex colors it works: when I re-import that file the mesh is colored by vertex. So Rhino is able to associate the displayed colors with the mesh vertices, just ComputeVertexColors doesn’t do it.
I see this in current R7 and the R8 WIP.
Thanks,
-Bathsheba
0000000.zip (4.5 MB)
Hi Bathsheba - it seems to be related to the bitmap - other images or textures applied to the mesh reasult in vertex colors being assigned. And this image on other meshes fails.
@Bathsheba it seems a workaround is to bring in the texture to the texture panel, make a new Custom material with that texture in the color slot, assign the new material, then ComputeVertexColors.
I tried opening the image in Photoshop and re-saving as 8-bit PNG, 24-bit PNG, and JPG; all failed. Weird. It’s like Rhino doesn’t like the colors, even though it can plainly read them perfectly well.
I can’t seem to apply your workaround…I put an image in the texture panel, but when creating a custom material I don’t see an option to choose from those images, only to import a file which doesn’t seem to work.
For what it’s worth, the bad image is already present in the panel and there’s already a custom material with it that is marked “Legacy V4” which seems maybe old? :woman_shrugging:
Anyway thanks for looking. I have a lot of these, the images are generated in Python by PIL.Image.fromarray() mode ‘RGB’.
We also have an open ticket at the moment to resolve some inconsistent behaviors we’re seeing.
https://mcneel.myjetbrains.com/youtrack/issue/RH-77165/ComputeVertexColor-command-doesnt-appear-to-work
RH-77165 is fixed in the latest BETA
Thanks! My particular example still fails in 8.0.23276.13303.
Hi Bathsheba, I see that, thanks
