Hi all,
I have two -kind of- complex geometries that I want to produce a boolean union with.
This is one of my first attempts to produce a cam file, so up until now I wasn’t so preoccupied with creating watertight solids.
most of the elements have been produced in grasshopper. and it would be a long run to go through the whole process again.
Do you thing that at this point I can save it?
any help will be appreciated.
Wasn’t there a way to extract the data tree from a rhino model? You could use that in grasshopper I think so you don’t have to go through the whole process. Never did it just it came in my mind that I read it somewhere.
The bottom face of the item on the Finished layer is the problem one. As an alternative approach to the one suggested above you can:
Explode the Finished object.
Create curves from the outer bottom face border.
Delete the two bottom faces.
Create a new bottom face using the outer curve as a planar curve.
Split it using the inner curves where there is a hole right through the object (but not the curve that divided the two original bottom faces) and delete the unwanted portions.
Delete the curves as they are done with.
Select all the objects on the Finished layer and join them.
Union the Finished object with the Layer 01 object - this will now work ok.
