Command line doesn't describe selections
Used to be, if I selected a polysurface, I would see “1 polysurface added to selection” in the command field at the top. Now, when I select anything, the command field says nothing. I kind of liked being told what I selected. Can I turn this feature back on?
Hello - that is not the case here…
I’m not sure what might turn that off…
Could it be that your command window height is so short that what you are looking for has already scrolled off the top?
