I just updated the new version of Rhino 7 and when I opened it, the command bar was no longer present. I even reset the panel tools to default and when I open a project the command bar is visible for a second then disappears again.
Hi @Kaitlyn_Eslick welcome, can you pls. type _SystemInfo in Rhino and post back the results here?
I figured out this problem. It fixed itself. Thank you.
