selecting the toolbars in the window menu and starting the snapshot slideshow then closing the toolbars…
Rhino8 (8.2.23346.13001, 2023-12-12)
gonna need a little more detail… can you describe what you are trying to do and what is happening when you try to do it?
redo the slide with your toolbar open.
when you run the slide it goes to whatever was recorded when the slide was created.
Sorry Kyle if I don’t specify much of what happens, I’m using the online translator.
Let me start by saying that I have a very old PC, so it could just be my problem. doing some tests I performed the presentation both without objects and with various objects such as: curves, spheres, solids and I had various bars in containers and a bar without container taken from the window menu.
I think the presentation command works well (I was actually trying it) it starts the time for each snapshot, then expands everything seems to work, then when I click STOP everything goes back to the way it was before, I view the objects as before and the bars in the containers are there are, only the toolbar that I had displayed from the window menu is missing
I see the same behaviour here-
if you make a new container and put that toolbar in it , does it behave as you’d expect?
as mentioned, the bars inside the containers remain.
