ClippingBox and Contour - odd result
Large mesh with 9 million faces.
Used new ClippingBox to display only part of the mesh.
Contour on the mesh.
Results in Top, Front and Perspective views as expected.
Result in Right view is strange.
Rhino 9 SR0 2026-6-30 (Rhino 9 BETA, 9.0.26181.12303, Git hash:master @ 63db21acdecff631b4b3c30057580aaff9bf8c35)
License type: Commercial, build 2026-06-30
License details: Cloud Zoo
Expires on: 2026-08-14
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 10.0.9
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 3-4-2026 (M-D-Y). DirectX(11)
- Windows Main Display attached to adapter port 0
Secondary graphics devices.
None found.
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\ClippingBox\0.2.2\ClippingBox.rhp “ClippingBox” 0.2.2.0
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26181.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26181.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26181.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26181.12303
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26181.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26181.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\Calc.rhp “Calc”
I expect that the scan without the clipping box would draw those contours in the right view normally?
Have you tried this with a simple mesh? In my tests I cannot recreate the odd curves in the right view.
Is there a simpler model that you can see this on?
I can’t repeat it now in BETA (9.0.26202.12303, 2026-07-21).
Perhaps the cause was resolved with the fix for a different clipping plane issue: Direct3D BUG Clipping Plane Display Fades Out
https://mcneel.myjetbrains.com/youtrack/issue/RH-96851
Good, that is what I was hoping. Thank you for checking.
