Direct3D BUG Clipping Plane Display Fades Out
Polycurves, each with several thousand points.
Single clipping plane in use.
The clipped display fades as I zoom out, with curves further away becoming fragmented and then vanishing.
Only occurs with Direct3D (Okay with OpenGL)
Only occurs in viewport(s) with clipping plane enabled
Does not occur with polylines are converted to simpler curves (included in example file below.)
Directly related to the magenta line in layer “Position GB”.
Turn layer “Position GB” off and the display is correct.
Turn layer “Position GB” on and the problem returns.
Clipping Plane Bug DC01.3dm (2.7 MB)
Zoomed in, all curves which should be visible are visible.
Zooming out.
Zoomed further out:
System Info updated after updating display driver and removing ClippingBox plug-in. Problem still occurs.
Rhino 9 SR0 2026-6-30 (Rhino 9 BETA, 9.0.26181.12303, Git hash:master @ 63db21acdecff631b4b3c30057580aaff9bf8c35)
License type: Commercial, build 2026-06-30
License details: Cloud Zoo
Expires on: 2026-08-14
Windows 11 (10.0.26100 SR0.0) or greater (Physical RAM: 64GB)
.NET 10.0.9
Computer platform: DESKTOP
Standard graphics configuration using DirectX
Primary display: NVIDIA GeForce RTX 2080 Ti (NVidia) Memory: 11GB, Driver date: 6-11-2026 (M-D-Y). DirectX(11)
- Windows Main Display attached to adapter port 0
Secondary graphics devices.
None found.
DirectX Settings
Safe mode: Off
OpenBLAS: OpenBLAS 0.3.30 DYNAMIC_ARCH NO_AFFINITY Haswell MAX_THREADS=64.
C:\Program Files\Rhino 9 WIP\Plug-ins\Commands.rhp “Commands” 9.0.26181.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk.rhp “Renderer Development Kit”
C:\Program Files\Rhino 9 WIP\Plug-ins\3dxRhino.9.rhp “3DxRhino.9”
C:\Program Files\Rhino 9 WIP\Plug-ins\UpdatesAndStatistics\UpdatesAndStatistics.rhp “UpdatesAndStatistics” 9.0.26181.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 9.0.26181.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 9.0.26181.12303
C:\Users\dcock\AppData\Roaming\McNeel\Rhinoceros\packages\9.0\PanelingTools\2024.8.20.677\PanelingTools.rhp “PanelingTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\NamedSnapshots.rhp “Snapshots”
C:\Program Files\Rhino 9 WIP\Plug-ins\MeshCommands.rhp “MeshCommands” 9.0.26181.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoCycles.rhp “RhinoCycles” 9.0.26181.12303
C:\Program Files\Rhino 9 WIP\Plug-ins\SectionTools.rhp “SectionTools”
C:\Program Files\Rhino 9 WIP\Plug-ins\Displacement.rhp “Displacement”
C:\Program Files\Rhino 9 WIP\Plug-ins\Calc.rhp “Calc”
Update: The problems still occurs when the layer Position GB with the magenta line is turned off, but is not as severe. Also the display driver was updated and plugin ClippingBox was removed with no improvement. SystemInfo in the post above was updated.
This feels like a problem with extents, possibly involving code somewhere which “simplifies” objects for display based on distance from the camera which interacts with the clipping plane code.
@stevebaer @wim @Gijs @jeff This needs to be added to the list. It’s repeatable and also occurs on my laptop, SystemInfo below. The laptop was updated to the latest NVIDIA game driver. My desktop, SystemInfo above, has the latest NVDIA studio driver.
Windows 11 (10.0.26200 SR0.0) or greater (Physical RAM: 32GB)
.NET 10.0.2
Hybrid graphics configuration using DirectX
Primary display: NVIDIA GeForce RTX 3070 Ti Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-2-2026 (M-D-Y).
- Laptop’s primary display device
Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 2-22-2023 (M-D-Y).
DirectX Settings
Safe mode: Off
C:\Program Files\Rhino 9 WIP\Plug-ins\WebBrowser.rhp “WebBrowser”
C:\Program Files\Rhino 9 WIP\Plug-ins\RhinoScript.rhp “RhinoScript”
C:\Program Files\Rhino 9 WIP\Plug-ins\IdleProcessor.rhp “IdleProcessor”
thanks for the report and sample model,
RH-96851 disappearing lines with ClippingPlane in direct3d
RH-96851 is fixed in Rhino BETA
