Removing Layouts or renaming clipping planes isn’t immediately reflected in the clipping plane panel. Changing “Sort Order” for example refreshes it though
Hi Daniel -
Just to make sure, which panel is that?
this one. Another issue is that checking/unchecking boxes shown below doesn’t persist. Once “Sort Order” is changed they all return to the state below (they do work though, clipping planes get disabled/enabled in the corresponding views, just the state in the panel seems to change)
You’re using a deprecated test command that was never completed. Is there a reason you arent using the normal clipping plane interface?
Travis you are right, I remember now that activated it long time ago and forgot that it’s experimental. Sorry, that makes sense now.
Ok no worries. I never got around to wiring up all of the document events to make it refresh which is why it doesn’t update. If you switch the UI sort order (by layout / by clipping plane) it will refresh its data.
