Hi!
For some reason, the cut line is leaving a silhouette from elements it already cut. In the image attached below, the lines to the right of the bold has already been cut. How can I fix this?
Thanks!
Hi!
Thanks!
Hi Feiga -
I’m afraid we can’t troubleshoot images. Please post a 3dm file.
Hi Wim,
Thank you for your reply.
Please find the model here:
3D Model - Nov 11.3dm (19.6 MB)
Thank you,
Feiga
Hi Feiga -
The same answer as the one in your other thread applies here. Having an extremely big (15 km) object in a scene with smaller objects leads to display issues. In your file, you can fix that behavior by turning off the “Ground” layer.
I’m not sure if this is something that can be fixed but I’ve put it on the list so that a developer can take a closer look.
→ RH-84953 Display: Large Object Unclips in Ortho Views
Wonderful!
Thank you so much, Wim.
