Hi there,
An error started happening with my clipping planes that I cannot seem to fix.
Please see the images attached with clipping plane off and then on.
It seems to be drawing lines from all objects to some kind of vanishing point. Not really sure what is going on so would really appreciate some advice!
Many thanks in advance
error 1 - with clipping plane on.pdf (1.4 MB)
error 1.pdf (1.5 MB)
pascal
(Pascal Golay)
May 8, 2019, 9:41pm
2
Hello - can you please post the object and clipping plane, or send the file to tech@mcneel.com ? Is the mesh far from the origin?
clipping plane error.3dm (7.0 MB)
It could be that it’s the curves? But I want these lines to be visible in the views so don’t want to turn them off… or is this not possible?
Many thanks
pascal
(Pascal Golay)
May 8, 2019, 10:35pm
4
Hello - this looks OK here - can you run SystemInfo in Rhino and paste the results here?
Rhino 6 SR13 2019-2-27 (Rhino 6, 6.13.19058.371, Git hash:master @ 17cd8b51accbe17dd04b48028f49d5e77a67f17b)
License type: Evaluation, build 2019-02-27
License details: Stand-Alone
Expires on: 2019-05-14
Windows 8.1 (Physical RAM: 7.9Gb)
Machine name: HOMEOFFICE
Non-hybrid graphics.
Primary display and OpenGL: Intel® HD Graphics 4600 (Intel) Memory: 2GB, Driver date: 10-10-2013 (M-D-Y). OpenGL Ver: 4.2.0 - Build 10.18.10.3325
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Vendor Name: Intel
Render version: 4.2
Shading Language: 4.20 - Build 10.18.10.3325
Driver Date: 10-10-2013
Driver Version: 10.18.10.3325
Z-Buffer depth: 24 bits
Total Video Memory: 2080 MB
Rhino plugins
C:\Program Files\Rhino 6\Plug-ins\Commands.rhp “Commands” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\AnimationTools.rhp “AnimationTools”
C:\Program Files\Rhino 6\Plug-ins\Tibidabo\Tibidabo.rhp “Tibidabo”
C:\Program Files\Rhino 6\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\RhinoCycles.rhp “RhinoCycles” 6.13.19058.371
C:\Program Files\Rhino 6\Plug-ins\Tibidabo\Lands.rhp “Lands Design”
C:\Program Files\Rhino 6\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 6.13.19058.371
pascal
(Pascal Golay)
May 8, 2019, 11:06pm
6
Hello - your video driver is ancient - let’s start there - can you please open the Notifications panel (Panels menu) and double-click the notification about the video driver - follow along there and see if you can get a later driver for your gpu. Install that and see if anything looks better.
