Only seems to happen with certain kinds of objects. Simple extruded shapes and solids are exempt, but lofted objects and objects imported as stp files from Solidworks get the treatment. No doubt this is simply solved, but I can’t (yet) find any reference to this problem in this forum.
Hello - thanks - I don’t know if it will matter, I’d be surprised, but please disable VRay in Options > Plug-ins, then close and re-start Rhino - does that change anything?
Hi, restored defaults on display modes, but it hasn’t made any difference. Would the fact that none of my default settings files are available, on startup, have any bearing on the problem?
By this do you mean template files? I would not think that matters for this but it is unexpected that they are not there - try running a ‘repair’ on the Rhino installation in the Windows control panel.
Hm - I wonder why it was off - we’d talked about disabling GPU tessellation on some cards that are known to have problems with it but I don’t know if we are doing that automatically now and your card is on the suspect list for some reason.
