Clipping plane bug in V8
please check the attached file:
while gumball-dragging the clipping plane, the three objects appear perfectly planar-capped at the cutting plane (screenshot 001). as soon as i release the mouse button, the cappings dissappear and the objects are displayed as open polysurfaces (screenshot 002).
see screenshots, please help …
clipPlane.3dm (1.2 MB)
Hi -
Thanks for that file!
I’m only seeing that happen for one object in the 8.13 version that I’m running here.
On the list as RH-84036 ClippingPlane: No Cap on Section Sample
Hello @wim ,
It seems that @stevebaer has already created a task for this. He asked me to send him the file, and he mentioned that he recorded it as an intersection issue. However.
Hi -
These issues are file-specific and the intersection issue in the code might not be the same. It’s important to report samples that fail.
partially solved:
  • reopened my file, checked “units … tolerances” (i always forget that .stp import sometimes cranks up this setting insanely) … tolerances were at 0.00001
  • set them to 0.01
  • clipping plane now works much better, still in some cases it fails to cap
opened the sample attached under the link above (Failure sample: No Capping On Section.3dm) and tested the solution described before (lowering the tolerances) which made the clipping plane work in the expected way.
