Clipping plane bug on V8?
the clipping plane sometimes fills an object but if i move the plane it doesn’t…
Both polysurfaces are closed so, why only a part of them is filled?
If i mesh the psurfaces it works like a charm…
Thanks!
systeminfo.txt (2.5 KB)
clippingplanes.3dm (503.9 KB)
it seems to be something related to non planar surfaces: it happens again with a box and a sphere
Interestingly, the fill is there while you move the clipping plane.
It disappears when you release the mouse button.
In V7 there are no flaws.
So this is a V8 bug.
@Gijs ?
yes, this one is on the list as RH-83092 Clipping plane fill missing
I added this thread
I have encountered a similar problem. The fills sometimes appear in the wrong place, and the cut edges seem incomplete. All the cut objects only have planar sub-surfaces. The corresponding clipping drawing works fine.
I’m adding this to this (solved) thread as I think this could be related to RH-83092, @stevebaer.
Clipping-Plane_Bug-Report.3dm (2.3 MB)
Rhino 8 SR13 2024-10-8 (Rhino 8, 8.13.24282.10001, Git hash:master @ 7fc2e504d4c838aa0264b02fb10e24ecfff2824a)
License type: Commercial, build 2024-10-08
License details: Cloud Zoo
Windows 11 (10.0.22631 SR0.0) or greater (Physical RAM: 32GB)
.NET 7.0.20
Computer platform: LAPTOP - Plugged in [80% battery remaining]
Primary display and OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-30-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.81
Primary OpenGL: NVIDIA GeForce RTX 4070 Laptop GPU (NVidia) Memory: 8GB, Driver date: 7-30-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 560.81
Secondary graphics devices.
Intel(R) Iris(R) Xe Graphics (Intel) Memory: 1GB, Driver date: 6-15-2023 (M-D-Y).
OpenGL Settings
Safe mode: Off
GPU Tessellation is: On
Anti-alias mode: 8x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 7-30-2024
Driver Version: 32.0.15.6081
Z-Buffer depth: 24 bits
Total Video Memory: 8188 MB
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V7\VRayForRhino.rhp “V-Ray for Rhino”
C:\Users\simon\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Users\simon\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\Bullant\24.10.6.8\bullant.rhp “bullant” 24.10.6.8
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.13.24282.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.13.24282.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoRender.rhp “Legacy Rhino Render”
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.13.24282.10001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.13.24282.10001
C:\Program Files\Rhino 8\Plug-ins\IronPython\RhinoDLR_Python.rhp “IronPython” 8.13.24282.10001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.13.24282.10001
C:\Program Files\Rhino 8\System\netcore\export_PDF.rhp “PDF Export” 8.13.24282.10001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.13.24282.10001
C:\Program Files\Rhino 8\Plug-ins\BlockEdit.rhp “BlockEdit” 8.13.24282.10001
Just a quick follow up on this — I noticed that these issues don’t seem to occur with a new clipping plane. What might be the difference between the two?
Clipping-Plane_Bug-Report_Follow-Up.3dm (2.2 MB)
hi @Simon_Vorhammer thanks for that file.
I could not find the cause of the difference either.
RH-84301 Strange behavior of clippingplane
RH-84301 is fixed in Rhino 8 Service Release 14
RH-83092 is fixed in Rhino 8 Service Release 14
