Clipping plane fills not showing consistently
It seems to either be related to multiple objects in the clipping plane’s space or complex objects. I’m not sure but it happens so frequently that I can’t rely on the clipping plane fills showing. When I move the clipping plane the fill appears then it disappears as soon as I release.
Hi Keith -
As always, we’ll need a 3dm file and the output of the SystemInfo command…
I was doing tests see if I could resolve it. It might just be a case of file tolerance. I think a previous boolean operation increased the file tolerance. I’ll do more testing as I work and see if I can verify that it was the tolerance.
If it’s just a matter of setting the tolerance to something appropriate that’s not a problem.
