Clipping Drawings - Unable to show hatches and curves
I am still exploring and learning how to use the ClippingDrawings function in Rhino8.
I am currently facing the issue where Hatches and Curves in the model are not able to get ‘passed through’ the ClippingDrawings, as shown in the screenshot below. This happens even after I have ensured that the hatch and lines are included in the ‘Objects’ for objects clipped.
I am doing this workaround where I put a hatch in the model as I would want to have some objects to have hatches (e.g. a wooden table with a wooden hatch) and then extract out the 2D drawings using ClippingDrawings (instead of adding the hatches on top of the 2D drawings after (as this makes more sense as a workflow to me)).
Is there a better workflow for this?
I find this weird as I would think that the clipping drawings should almost essentially be the “same” as clipping planes, if that makes sense.
Attached files for reference:
test clipping drawings.3dm (479.7 KB)
Hi Owi -
I’ve put this on the list as RH-85431 ClippingDrawings: Support Background Curves and Hatches
RH-85431 is fixed in Rhino WIP
