Hello, apparently there is a bug with the UpdateClippingDrawings command, because the section is often not updated, “changes in the model are ignored” and the hatchings are also partially mirrored. Furthermore, the hatchings are simply not displayed and only a fill area is created.
I work with real coordinates, mostly in Gauss Krueger, in the range of 20,000 - 4,000,000 and I have no idea whether that’s why Rhino has problems with it.
Hello Japhy,
could you send me the link again where you can report a bug and upload files outside of the forum, unfortunately I can no longer see your second link.
I have prepared the file so far and generated the Txt file using the Systeminfo command.
Hello Japhy,
Is there any news regarding my bug report?
Unlike in the past when I reported a bug, this time I unfortunately didn’t receive any response by email and the bug (hatching alignment) still exists in the latest version.
I did it a month ago (uploaded an explanation in German and English including the file and system information) but this time I didn’t receive a response by email like I usually do, so I asked you if you already knew anything.
Ok, then I will send the file and the report about the bug in English including the system information via your upper link and hope that it arrives this time. Thanks
Hello Japhy, I have attached a simple test file that shows the error with the alignment of the hatching. In the image you can see that everything is displayed correctly in the 3D view and it only occurs in the section drawings. I hope it helps to eliminate the bug.
