Clean Uninstall
Hello, I have still in Rhino Beta the issue, that right click does not work as expected. Here is the popup toolbar where I cannot access right click commands. As I have to double right click on several items in Rhinos bottom toolbar to access Gumball and such.
Did all what was written here, is there any place to get this working? Have only Keyshot installed as a plugin, uninstalling it does not help.
https://wiki.mcneel.com/reset_to_defaults
Thank you
Hi Hannes -
Those instructions are for Rhino 6 and 7.
In Rhino 8, you can use the Reset command and pick the reset level that you want.
thank you @wim
@wim I tried but I encounter the issue no matter what. So right click almost never works. Sometimes it works when I tried for 10 consecutieve times. Is there something which I have to do. Tried delete all related from the registry to no avail.
Can you help me. I need right click and currently work with pasting between both versions (7 and 8)
Thank you
Hi Hannes -
I must admit that this sounds more like a hardware issue with the mouse than anything else. Have you tried this with a different mouse?
No problems in version 7. This is a new mouse from 3dconnexion.
Hi @hannesgrebin,
perhaps you mean this problem: Toolbar buttons require an extra click
Regards
Michael
Hey @Michael_Meyer it occurs just when hovering and right click. As richt click does not work. With bottom toolbar I can access it while holding Ctrl and then RMB click.
With floating toolbars I can not access icons with a RMB command assigned to as CTRL would normally show the edit or copy command on pallette icons. So It would not work.
I think this is something with a bad settings file or such. That is why I would like to have maybe a workaround to delete all registry leftovers. Maybe a clean-up tool for Rhino.
As said the only plug in I use is for keyshot and with or without the plugin the same error occurs.
