Hi!
When I click “restore toolbar” in Rhino 8 nothing happens.
I’ve lost the default toolbar and now I don’t know how recuperate it.
Not sure where you click this…
Have you tried _Reset?
Rhinoceros Help - Toolbar options | Rhino 3-D modeling (mcneel.com)
Yes!
If I try delete a button, don’t run! Rhino don’t delete nothing…
Hi Oscar -
Which option did you use?
Based on the problems you’re having, I’d try the Factory Reset.
If you have lots of customizations, use the “Save Settings” button first.
I suspect that you are running into this bug:
RH-77523 Rhino needs a restart to be able to see a deleted button
Solved!
Thank’s.
Now I would like to duplicate the default library (toolbar) and I don’t know how… or discover how show the name on left in othe library…
RH-77523 is fixed in Rhino 8 Service Release 2
I got toolbars disappear. I could not reset because Tool/Options/toolbars does not show “reset to default” button.
What command brings that black window “Reset Rhinoceros to Defaults” visible?
aki
Just Reset
