@JimCarruthers I canât do it. The window disappears. Hence I found out there is a hidden option in the âreset pc commandâ that will wipe out all settings. Will come back then.
@JimCarruthers so Iâm back with a clean install without any restored Windows settings, the option mentioned above did the trick. No issues so far. Thanks for your help.
@tay.othman you are right. in version 8 there are issues with StrokeIt which is a mouse gesture application. Once turned off there are no issues. Thank you
