Hi!
Does anyone know some configurations in rhino render to make the clay style? Similar to this one, for example:
It’s possible only with rhino render or it’s better with plug-ins like V-ray?
thank you
In V5 you need to turn on skylight. You find that in the “sun tab” (just type “sun”)
and then set all objects to use the default material.
(Or extract all rendermeshes and join them and assign a default material to that one new mesh object)
Good luck!
try Thea Render. Then Just press CLAY RENDER and Choose 50% of it, plus Ambient Oclusion 10% + 40%. et Voillá.
the clay render mode is available also in brazil,vray and thea using the relative menu
