Trying to find ways of working faster setting up a rendered scene and evaluating the scene with light before applying materials and just being able to do fast renderings
Anybody have any technique of temporarily change materials to one material in order to render a clay render for faster workflow?
Say if you have a architectural scene with a lot of materials that are applied to different objects with Assign to Object (because applying by layer would result in too many layers…)
Thought of making an duplicate of Rendered Display Mode but can’t find any options of choosing a different display mode in the render options. It is important that pixel count of the clay render (whatever method) is the same as the rendered setting.
I tried using RenderArctic but somehow it didn’t work on some objects - they still rendered with the applied material. Tried ungroup the faulty objects but it didn’t change.
A second question: How could I make use of the materialID and ObjectID? I tried saving out as a exr-file but my photoshop doesn’t let me work in 32-bit, I have to convert it to 16-bit which makes it look terrible and useless. Is there any other method of saving out these passes for further processing in Photoshop?
Make a copy of Arctic mode. Go to the general settings for this copy and under shading settings for Color and material choose Custom material for all objects. Then click the Customize… button. Scroll down to Environment and choose a map file. Select a matcap file that you like.
Then go to Other settings and for Realtime Renderer Assignment choose Cycles.
Thanks for the clear explanation and tips! I tried using a matcap but not sure of a useless resolution of the jpeg. Not sure really what the difference between a matcap and a diffusemap.
Tried to find a useful matcap but didn’t find any so I don’t know if my experiment of the settings make my evaluation of the setting any useful judging by the result.
Matcaps are essentially sphere renders that have shading in them. When those are put in the environment slot (or with environment mapping if you put it in a regular material) those get evaluated with an environment mapping giving a nice effect.
You can search for instance for matcap white clay and you get multiple good looking images. I used matcap clay white at DuckDuckGo for a quick search and tried the first one at pmndrs market - , which looks like
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 24GB)
.NET 7.0.20
Primary display and OpenGL: NVIDIA Quadro P1000 (NVidia) Memory: 4GB, Driver date: 1-2-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 538.18
Primary OpenGL: NVIDIA Quadro P1000 (NVidia) Memory: 4GB, Driver date: 1-2-2024 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 538.18
Secondary graphics devices.
Microsoft Basic Display Adapter (Intel) Memory: 0MB, Driver date: 6-21-2006 (M-D-Y).
> Integrated graphics device with 1 adapter port(s)
OpenGL Settings
Safe mode: Off
Anti-alias mode: 2x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 1-2-2024
Driver Version: 31.0.15.3818
Z-Buffer depth: 24 bits
Total Video Memory: 4 GB
C:\Users\nilsw\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\NVIDIADenoiser\0.4.3\NVIDIADenoiser.Windows.rhp “NVIDIADenoiser.Windows” 0.4.3.0
C:\Users\nilsw\AppData\Roaming\McNeel\Rhinoceros\packages\8.0\SubstanceImporter\2.0.7\Substance.Win.rhp “SubstanceImporter” 2.0.7.0
C:\Program Files\Chaos Group\V-Ray\V-Ray for Rhinoceros\V6\VRayForRhino.rhp “V-Ray for Rhino”
