Is there any way I can import vector data from a WFS-Service into Grasshopper? The WFS I would like to access responses in CityGML-Format. I haven´t found any CityGML-Importer so far
You can use the xml parser from ghowl.
and Heron Gdal ogr2ogr.
Where are you getting your CityGML from?
As Japhy points out AntFarm can import CityGML and it is possible to write a direct connection to a WFS Service. I would suggest that you try downloading the GML files first and importing them into AntFarm. If there is enough demand at a later date we could look to writing a connector.
