image|690x460
I WANT TO RECREATE THIS TYPE OF GEOMENTRY USING GRASSHOPPER . I TRIED USING ARRAY BUT THE SPACING AND SCALING . I ADDED MY SCRIPT BELOW .
I WANT SOME HELP REGARDING THIS
ARRAY SCALING.3dm (235.2 KB)
ARRAY SCALING.gh (6.9 KB)
this could be a starting point:
ARRAY SCALING_Re.gh (17.9 KB)
if you want the corner of each shape to touch the previos/next, then using an array along curve is probably not the best solution because they would be equally spaced, while you want them to be spaced proportionally to their size
WOW THANKS MATE , U REALLY DID IT LIKE AN EASY JOb. I learnt my mistake will work on it . thanks again
