Hi all, I am making a conceptual tower and I have set up the geometries so that it is in a series. I want each curve to be progressively smaller as it reaches the top. Is a plugin required for this? If so, the name of the extension/potential solution would be highly appreciated. Also, how would I set this geometry up for fabrication via the orient command? Thanks so much in advance.
scaling + open nest.gh (14.5 KB)
@Joseph_Oster Do you happen to know how to scale each curve by a set factor? Would it be somewhere in the linear array/series?
I was just about to post this, after noticing the thread title, Instead of scaling, I reused the same Graph Mapper output to set the “radius” of the polygons. You might want different graphs for rotation and radius? And change the thread title?
scaling_2023Feb26b.gh (14.3 KB)
Thank you so much for all of the information and assistance, I really appreciate it!
