When ever I attempt to change settings to the -ViewCaptureToFile command, a file called _Enter$.jpg is saved.
I assume this is a bug. Can anyone else replicate this problem?
I am using Rhino 6.0
I don’t see that happening here in a couple of quick tests. Can you post a step-by-step of what you are doing?
–Mitch
Solved. The problem was my Rhino 5 aliases confusing matters. Apologies and thanks!
Any change of persistent settings returning for -ViewCaptureToFile ? I have to enter custom width and height every time.
