Is my memory failing me, or did it used to be the case that a viewport became active if the mouse pointer was in it and you zoomed with the mouse scroll wheel? In my current model, it doesn’t. V5, latest service release.
I’m point editing a surface using nudge keys to match to some imported data. Standard 4 viewport layout. Leaving CP’s selected, if I switch from one viewport to another the only way I can get Rhino to change focus without de/reselecting the points is to right-click Pan. I’m sure I always used to do this by scroll-zooming but that doesn’t work.
I’ve not had cause to free form surface-model in a while. Great fun in Rhino…
IIRC, the behavior changed because of some Windows OS thing. That is, it works one way on Win 7 and another way on Win 10. It’s beyond the control of the application…
This change of nudge behaviour in V5 is a complete PITA. Is there any chance of a SR to fix it? I’ve been caught out by it 3 times already today. It could be very costly if I’m not alert to it. I appreciate what wim says and know it’s not the fault of Rhino, but…
Glad this thread was created. I thought it was something in what I did. Once the directions are understood, will it stay that way? That is with nudge and the arrow keys. —Mark
Hi Tobias,
That is correct. In Rhino 5 on Win 10, a viewport doesn’t become active when only zooming with the mouse wheel. Zooming with Ctrl + RMB will make it active.
