I’m currently trying to adjust the height of multiple walls. Is there a way to select them and change their height quickly, or do I have to change the properties of every single one individually?
They have different thicknesses.
Hi Marek,
You can change the height of multiple walls at once by selecting them, and from the properties panel, select the wall icon, and change the height.
Hi @flavien.bessiere applying an increment of height to a multiple selection of walls is something that can be only achieved through Grasshopper, using the Update Property component. Find attached gh file to do it.
Thanks for this solution. I will deal with this for the moment. Do you know if there is a way to trigger the update property button (via HumanUI for example).
Hello there,
Maybe the simpliest idea is to have a special style? And to have all walls with heights “by style”? And to change their heights just by modyfing the style?
I know, it makes no sense with a lots of styles, and this is why some time ago I asked about a kind of “family” of styles. This way you could have one “parent” definition, with all desired parameters, and a set of “children” styles with different heights (or any minor modifications). All the rest could be inherited just “by parent”…
Cheers, Jaro
