Change background from grey to white
This is probably a simple question how do I change the background to white?
Options>Appearance>Colors… You might also want to modify your grid colors if you use the grid (same place). --Mitch
thanks for the help. The mistake I was making is when you first click on appearance there is a background on thaat page which I had set to white.but I think its refering to text rather than the background of the viewport
That one is setting the background color of the command prompt - the box where the commands and their feedback are printed.
What am I missing here. I changed it to white for one purpose, and now want to change it back to gray, as my client has a bunch of yellow layers that I can barely see. I’m changing background back to gray but it’s still showing white. How did I break it? I even tried restarting in case it needed to reinitialize or something, no luck.
Hello - yeh… the viewport background color set at the application level can be overriden by a display mode - see the Display panel for the current display mode settings…
Ah yes thank you. That, is how I broke it :slight_smile:
As of June 19th (2021) and Rhino V7 changing background color from gray to white
view >>> display option >>> rhino options >>> appearance >>> color
Thank you so much omg!!!
I have to make this change regularly. Des someone know how to write a macro for this? (change to white - change to default gray)
ah thanks was trying to work out what I had done
Hi, have you figured out about macro?
Hi -
The easiest would probably be to create a copy of the display mode and use the SetDisplayMode command to use it in a viewport.
I write a simple python code:
import Rhino
import System.Drawing
def layout_change(color):
# Get the current appearance settings
appearance_settings = Rhino.ApplicationSettings.AppearanceSettings
# Create a new color using the RGB values
new_color = System.Drawing.Color.FromArgb(color[0], color[1], color[2])
# Set the page view paper color
appearance_settings.PageviewPaperColor = new_color
# Specify the RGB color values (e.g., WHITE)
color_rgb = (255, 255, 255)
layout_change(color_rgb)
I have changed ‘layout’ from grey to white… but for ‘shaded view’ (only) it still only shows grey no matter what ?
what am I doing wrong ? this is a new issue I have never had before btw
edit : seems to be related to using a named view (based on Cplane)
EDIT : PLEASE IGNORE
I realise there was a large element in the background of the model which was shaded and causing the issue
If it’s still relevant, I made a button to change the background color. Inspired by Maya.
CycleBackground.py (1.3 KB)
ResetBackground.py (583 Bytes)
macOS
! _-RunPythonScript “/Users/username/yourScriptLocation/XYZ.py”
Windows
Example Disk F!
! _-RunPythonScript “F:/CAD/Rhino/Scripts/XYZ.py”
Had this for quite awhile… As it changes the general background color, one disadvantage is that it does this instantaneously for all instances of Rhino that one has open at the time. OTOH, I made it so that it re-calculates the grid colors based on the background color chosen, so that they are subtly lighter (for darker backgrounds) or darker (for lighter backgrounds) than the background.
