hello, i do have my rhrino set in milimeter
so when i calculate an Area i do have the result in square millimeters
is there a comand line to set it to square meter or other
idem for the Volume ( cubic millimeters )
thank you
thank you
If you run your command, Area or Volume before you select any object you should have the ability to change your output measure. I am using Rhino for mac, not firing up the Windows box. It should be the same. I work in millimetres also.
The command output …
IHTH «Randy
yes , i should have try this before…
to much used to select the object before…
thank you
