is there a way to preset the units in Area and Volume commands for all rhino files? I mostly model in Centimeters, but i need the area units in meters. I know i can preset the units when i start the command first time in the drawing, but that means I have to preset it every time i open a new drawing and for area and volume separately.
Hi Jakub- you can trick Rhino by adding the command to your startup commands (Options > General page) and then exiting the command after setting the units:
_Volume _Units _Meter _Enter
The Enter there kills the command without a selection but the unit is set for when you run Volume again.
nice… I was curious if this solution was going to work out for you since I’m in a similar boat. model in inches but always need area in sqft and volume in cu.yds…
(I can’t try it out myself since I’m on mac and startup items aren’t implemented yet but this looks promising)
that’s in my startup macro.
(not exactly a startup macro since it’s not automatic but i have one macro that does a few things and i usually run it upon launching rhino)
