Chamfer edge problem
Hello, I have a problem with the chamfer function. I have a 20x20x20 cube, when I execute the “ChamferEdge” command with Chamfer distance at 20, Rhnio creates the surface badly. I will add that the Rhino version is Version 7 SR20 (7.20.22193.9001, 2022-07-12).
Can something be done about it, or does it have to be that way?
Thank you in advance for your help.
The chamfer must be less than the minimal width of adjacent surfaces…
The command line also tells you this: “Failure in trimming input.”
Ok thank you, I just never paid attention to it ;).
Thank you for the explanation
