Certainly an easy fix, but I'm stuck...Why can i not select objects directly anymore, but only from a point perpendicular to the cplane?!
Please help, this is very frustrating.
I accidentally turned something on, and now when I type “move” (In 3d view) or any other command and select an object, Rhino will automatically select it all the way from the c-plane rather than from the point I clicked on the object itself.
For example, If i click to move a box in space, and click on a corner, the reference point will not be on the corner, but on the cplane, perpendicular to the corner.
thanks-
chuss
You turned on Project. You can uncheck it in the OSnap toolbar, or use ProjectOsnap Toggle to turn it off again.
Sam
Indeed I did. Thank you Sam!
