Can't select curve
Hi all. This is a silly question, but I can’t select the curve. When I click on the curve nothing happened but sometimes (rarely) select correctly.
Selection filer disable.
I’m using rhino 8 trial
curves.3dm (46.1 KB)
Hi -
Please run the Rhino SystemInfo command and copy-paste the result here.
Rhino 8 SR0 2023-10-31 (Rhino 8, 8.0.23304.09001, Git hash:master @ 20e15cf9bd66e6676f849f22e485cb3e82a8beac)
License type: Evaluation, build 2023-10-31
License details: Stand-Alone
Expires on: 2024-02-07
Windows 10 (10.0.19045 SR0.0) or greater (Physical RAM: 16Gb)
.NET 7.0.13
Computer platform: DESKTOP
Primary display and OpenGL: NVIDIA GeForce GTX 1080 Ti (NVidia) Memory: 11GB, Driver date: 11-22-2020 (M-D-Y). OpenGL Ver: 4.6.0 NVIDIA 457.51
OpenGL Settings
Safe mode: Off
Anti-alias mode: 4x
Mip Map Filtering: Linear
Render version: 4.6
Shading Language: 4.60 NVIDIA
Driver Date: 11-22-2020
Driver Version: 27.21.14.5751
Z-Buffer depth: 24 bits
Total Video Memory: 11 GB
C:\Program Files\Rhino 8\Plug-ins\Commands.rhp “Commands” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoRenderCycles.rhp “Rhino Render” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\rdk_etoui.rhp “RDK_EtoUI” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\MeshCommands.rhp “MeshCommands” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoCycles.rhp “RhinoCycles” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoCode\RhinoCodePlugin.rhp “RhinoCodePlugin” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\Toolbars\Toolbars.rhp “Toolbars” 8.0.23304.9001
C:\Program Files\Rhino 8\Plug-ins\RhinoLabsTools.rhp “Rhino Labs Tools”
C:\Program Files\Rhino 8\Plug-ins\import_OBJ.rhp “Import_OBJ” 8.0.23304.9001
Thanks.
When you click on a curve, is anything written to the command line? Does the content of the Properties panel change?
Hello- please update the gpu drives to the latest available on the NVidia website. Does that sort it out?
I’m having the same problem, i can select curves by making the square selection but not by cliking them, with polysurfaces happens something similar, i only can select them if the view is not wireframe, I have a mac M1
will leave here the SystemInfo results but it seems like a bug in Rhino:
Rhino 8 SR6 2024-4-10 (Rhino 8, 8.6.24101.05002, Git hash:master @ 32c244aa711e0034e75bec2e87d093c764820b96)
License type: Educational, build 2024-04-10
License details: Cloud Zoo
Apple macOS Version 14.4.1 (Build 23E224) (Physical RAM: 16GB)
Mac Model Identifier: MacBookPro17,1
Language: en-PE (MacOS default)
.NET 7.0.0
Metal GPU Family Apple 7
Metal GPU Family Common 3
Metal GPU Family Mac 2
Graphics processors
Apple M1
Color LCD (1440 x 900 @ 60.00Hz)
USB devices
None
Bluetooth devices
None
Third party kernel extensions
None
Third party plugins
/usr/lib/usd/libusd_ms.dylib
/usr/lib/swift/libswiftCoreML.dylib
/usr/lib/swift/libswiftFileProvider.dylib
/usr/lib/swift/libswiftGLKit.dylib
/usr/lib/swift/libswiftGameplayKit.dylib
/usr/lib/swift/libswiftMetalKit.dylib
/usr/lib/swift/libswiftModelIO.dylib
/usr/lib/swift/libswiftSceneKit.dylib
/usr/lib/swift/libswiftSpriteKit.dylib
/usr/lib/swift/libswiftVision.dylib
/usr/lib/swift/libswiftShazamKit.dylib
/usr/lib/swift/libswiftObservation.dylib
/usr/lib/swift/libswiftVideoToolbox.dylib
/usr/lib/swift/libswiftWebKit.dylib
/usr/lib/swift/libswiftNaturalLanguage.dylib
/usr/lib/swift/libswiftMapKit.dylib
/Applications/Rhino 8.app/Contents/Frameworks/RhMaterialEditor.framework “Renderer Development Kit” 8.6.24101.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/Commands.rhp “Commands” 8.6.24101.5002
/Applications/Rhino 8.app/Contents/PlugIns/NamedSnapshots.rhp “Snapshots” 8.6.24101.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RDK_EtoUI.rhp “RDK_EtoUI” 8.6.24101.5002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/MeshCommands.rhp “MeshCommands” 8.6.24101.5002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoRenderCycles.rhp “Rhino Render” 8.6.24101.5002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCycles.rhp “RhinoCycles” 8.6.24101.5002
/Applications/Rhino 8.app/Contents/PlugIns/SectionTools.rhp “SectionTools” 8.6.24101.1002
/Applications/Rhino 8.app/Contents/PlugIns/Displacement.rhp “Displacement” 8.6.24101.1002
/Applications/Rhino 8.app/Contents/PlugIns/PanelingTools.rhp “PanelingTools” 8.6.24101.1002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoDLR_Python.rhp “IronPython” 8.6.24101.5002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/GrasshopperPlugin.rhp “Grasshopper” 8.6.24101.5002
/Applications/Rhino 8.app/Contents/Frameworks/RhCore.framework/Resources/ManagedPlugIns/RhinoCodePlugin.rhp “RhinoCodePlugin” 8.6.24101.5002
In the Rhino 8 pull-down menu > Settings > Modeling Aids tool > Click the “Restore Defaults” button.
Any better?
Hi all,
Having the same issue in R8.
Reopen the Rhino file and it fix it.
But Having the issue for a second time, I suspect the filter to cause that issue.
I do have a shortcut to enable filter on and off.: '_selectionfilter
  • Usually in R7 it just toggle filter on and off (disable/enable)
  • Under R8 it seems that this command no longer toggle on and off… but rather bug the file. Does the same as @Piero_Rodriguez : can select curves by mnaking square selection but not by clicking them. Although, there are some that still be selectable but didn’t have anymore their editpoints on…
Charles C.
can you send a screen shot of what your selection filters are set to?
these are mine-
@theoutside ,
I have the same settings
I play with them, and doesn’T fix the issue.
There is something with the command.
Inevitably, each time I use : '_selectionfilter and after toggling off the command (manually)
only some of the curve become unselectable. Other curves can be selected but their points are not anymore.
I have to restart rhino to fix the issue. Anoying.
Any idea on how to toggle on and off filters if its not this commande ? (I have alias assign to it).
Thanks,
Charles.
@LeGaulois pls run _SystemInfo in Rhino and post back the results.
Hi Charles -
To answer this part of the issue…
The SelectionFilter command, when run that way, only allows you to set the visibility state of the selection filter dialog. To toggle the enable/disable state of the filters, you’ll need to run
-SelectionFilter DisableFilter Enter
I’d try running SelectionFilterNone in those cases.
@wim,
When I enter lets say verticies selection filter mode (shortcut for me : '_selectionfiltervertices) I got this :
Then, executing `SelectionFilterNone I end up with this
which is not bad but I just want to turn it off. disable it.
OR executing -SelectionFilter DisableFilter Enter, I got
And have to manually uncheck the Sub-objects
This is why I remember wanting toggle on/off selection filters.
Any idea ?
C.
Still use shortcut to quickly switch between types of selections.
  • verticies selection only : vv : selectionfiltervertices
  • curve selection only : ee : selectionfilteredges
  • face selection only : ff : selectionfilterfaces
  • Quit selection filter : qq : …
