No matter what I try, it won’t work. I followed the instructions on the popup shown here, but it won’t work and just keeps giving me the same error. What do I do to print a pdf? Please help! I can’t send client my work update.
I dont use print to pdf but rather print to the printer then save as pdf under the print dialog.
I’d check to make sure the layout size matches the paper size, as if they arent the same weird stuff ensues.
Hi Peter -
On macOS, don’t use Print but ExportAll to create a PDF file.
THANK YOU. Solved!
Thanks Lewn, but @wim suggestion ExportAll is easier.
