PDF printer for Mac OS
I want to add a PDF printer for use with the Mac version of Rhino. I need to be able to scale the PDF to paper sizes that are not supported by my office printer. I used to use PDF995 for Windows version but it seems it doesn’t work with Mac. Any suggestions?
hmm… printing to PDF is built in to os x… or, you don’t need to install anything in order to do what you want.
in the print dialog, you’ll see ‘Paper size’… which will include pre-defined sizes or those available from your printer driver… there’s also an option to create custom sizes… so make your custom size paper then at the bottom-left of the print dialog, you’ll see a PDF dropdown… from which you can save to PDF
Thanks Jeff! Works fine.
