Can´t Print to PDF Custom paper size (2050x400) mm
i have a layout confg with a paper size (2050x400) mm.
But trying to print to PDF the file there is no way to put those sizes …
The options of paper size are too limited
That must be a limitation of the printer driver you are using, not a Rhino thing. Install another PDF printer.
Looks like you Rhinoceros version has its own limitations too…
To your question, click that properties option and you can figure it out I believe…
I also used to do this for printing on a big plotter.
From what I remember is that you can set a custom size from the plotters driver.
If that doesn’t help you can also make a image file with custom size and print that.
(but that leaves the question if the scale is still correct)
I found this very useful if you’re thinking of printing a PDF on a custom size paper
https://helpx.adobe.com/acrobat/using/using-pdf-printer.html
Hi Hayden -
We have no control over how the Adobe PDF printer works. You have resurrected a thread that was started before the Rhino PDF printer was added. Please use the Rhino version.
Hi Wim,
Thanks for your reply. I’m not sure what the situation is with R7 but the raster quality in Rhino PDF is not very good (hazy) and the vector lines are very heavy (can’t differentiate the shades of greys for instance). I’ll have to think of another way to work around this issue.
Best,
H
Hi there,
**RhinoPDF doesn’t output vector still (2026)
**And it looks like Adobe PDF neighter…
Someone noticed it also ?! I can’t get vector output. (P.S. I didn’t made any make 2D for my drawings, they still 3D perspectives of 3D objects. Does it matter?)
Solution for custom page size printing with Adobe PDF :
Here is the way to go with custom pages with adobe PDF if someone is still looking:
Cheers,
CC
Hi Charles -
Yes, that matters.
If you want vector output from 3D objects, you need to put the viewport in one of the technical display modes.
Ah! I finally manage to make an VectorOutput with AdobePDF and custom size.
Tehnical and Pen ViewDisplay in 3D allow you indeed to output Vector PDF and not others. Good to know.
Thanks @wim
CC
