Can't Input R8 License For R7 Access?
I am trying to study some of the github developer samples which mostly need R7 to run from Visual Studio and see that I can get access to R7 with a valid R8 License here:
https://www.rhino3d.com/access-rhino-7/
However, my R8 license is a different format than the input field for the license so I can’t actually use the web page to gain access.
Any help is appreciated,
Thank you!
I just used your Rhino 8 Key successfully, check your work email for the Rhino 7 key.
*the key is in your Rhino account, try and open Rhino 7 to login.
If you add your license to an individual Cloud Zoo account, you can log in to Rhino from any machine without needing your license key.
It’s way better than keeping up with keys and worrying if you can activate a new workstation or laptop. As log as you are only using one machine at a time, you can have it on a number of devices.
Solved via email, thank you both.
Your support and promptness of response is unparalleled across the software landscape.
You all are the best, thank you!
