(venv) PS D:\Python\Test> D:\Python\Test\venv\Scripts\activate.bat
(venv) PS D:\Python\Test> pip install ghhops_server
Collecting ghhops_server
Using cached ghhops_server-1.5.4-py2.py3-none-any.whl (11 kB)
Collecting rhino3dm
Using cached rhino3dm-8.0.0-cp39-cp39-win_amd64.whl (2.3 MB)
ERROR: rhino3dm has an invalid wheel, rhino3dm has an invalid wheel, .dist-info directory not found
This goes along with my other topic where my hops simply doesn’t work with flask for some reason:
I can install it now, thanks, it still creates this problem when trying to use ghhops and flask:
[INFO] Solving using legacy API: <HopsComponent /math [b -> math -> result_path] >
[INFO] 127.0.0.1 - - [22/Mar/2023 18:01:59] "POST /solve HTTP/1.1" 500 -
[ERROR] Error on request:
Traceback (most recent call last):
File "D:\Python\Test\venv\lib\site-packages\werkzeug\serving.py", line 333, in run_wsgi
execute(self.server.app)
File "D:\Python\Test\venv\lib\site-packages\werkzeug\serving.py", line 320, in execute
application_iter = app(environ, start_response)
File "D:\Python\Test\venv\lib\site-packages\flask\app.py", line 2551, in __call__
return self.wsgi_app(environ, start_response)
File "D:\Python\Test\venv\lib\site-packages\ghhops_server\middlewares\hopsflask.py", line 42, in __call__
response = self.handle_POST(request)
File "D:\Python\Test\venv\lib\site-packages\ghhops_server\base.py", line 75, in handle_POST
res, results = self.solve(uri=uri, payload=data)
File "D:\Python\Test\venv\lib\site-packages\ghhops_server\base.py", line 126, in solve
return self._process_solve_request(comp, payload)
File "D:\Python\Test\venv\lib\site-packages\ghhops_server\base.py", line 192, in _process_solve_request
res, inputs = self._prepare_inputs(comp, payload)
File "D:\Python\Test\venv\lib\site-packages\ghhops_server\base.py", line 241, in _prepare_inputs
value = in_param.from_input(in_param_data)
File "D:\Python\Test\venv\lib\site-packages\ghhops_server\params.py", line 209, in from_input
for param_value_item in input_data["InnerTree"]["0"]:
KeyError: '0'
Thanks, please explain if you can - there’s no defined variable called input_data, I made a super simple definition to test:
def math(b):
if b:
print(input_data)
resultmath = 1+2
return resultmath
The print from inside the definition doesn’t work as it shows me the errors above and again:
[INFO] 127.0.0.1 - - [24/Mar/2023 15:15:56] "POST /solve HTTP/1.1" 500 -
KeyError: '0'
Outside the definition it simply gives me a syntax error:
I deleted Python entirely from my computer, from Path and all, and then reinstalled only one version (Python 3.10), created an entirely new project based on the fresh Python install and that solved it.
