Cannot get a correct measure for angle
Hello everyone,
I’m trying to measure and annotate (dimangle) the angle between two faces of one side of my object. And repeat this operation for the 4 other sides.
I only tried with the first side, but I cannot seem to get a coherent value. The command will write down wierd values (190°, 33°,…).
Could you please have a look?
You can refer to attached images and file.
thanks!
Lampe 03 02.3dm (6.5 MB)
Hi @cgepner, use _DimCreaseAngle.
also, in general, Rhino dimensions work in the active CPlane of the current viewport. To measure the angles of the surface edges, you’ll need to set the CPlane properly before creating the dimension.
_
c.
Try DimCreaseAngle?
thanks @clement
could you please explain what cplane i should set in my specific case?
I tried setting one of the two surfaces (that i’m trying to get an angle out of) but it didn’t seem to work
thanks
Hi @cgepner,
for _DimCreaseAngle, you do not have to set a CPlane and usually for measurements you could do this without changing CPlane. To measure the angle of the border edges (of the 2 touching planar surfaces), you might just extract the edge lines using _DupEdge, make sure they are linear (your’s where not, i used _SimplifyCrv on them) and while keeping both lines selected, run _Angle and choose the _TwoObjects command line option to print the angle.
For drawing angle dimensions, CPlane should be set. In your case you might use _CPlane _3Point and click the origin where the edges meet, then X and Y somewhere on the edge as shown below. Then you can make eg. an arc which you can pick with the _DimAngle command.
To set back the CPlane, use _CPlane _Undo.,.
_
c.
To measure the angle between two planar surfaces without creating a dimension use Agnle with the TwoObjects option.
Angle then the TwoObjects option
Select two planar surfaces.
@davidcockey, if i try this with the model posted and pick the surfaces, i get:
Angle = 33.564
obviously, the reflex angle.
@pascal, i think this thread is a wonderful example to show where the angle measurement and angle dimension commands could be improved. It is not possible to measure properly by picking sub-objects and using them with the TwoObjects option (prints nothing when edges are picked) nor does _DimAngle work using the _Points option, it always constrains to World.Top.
_
c.
Angle with TwoObjects provides the smaller angle (0 to 90 degrees) between two planes independent of the normals of the planes.
A geometry fundamental. The angle between the edges of two surfaces will not equal the angle between the surfaces unless the edges are normal to the intersection line of the two surfaces (extended if needed to intersect).
Yeah, I see that…
so is the main thing to look at the Angle> TwoObjects command? Edges (Sub-objects) may return different numbers than curves duped from the same edges…
Hi @Pascal, yes for the _Angle command using _TwoObjectsoption i would have expected that with a post-selection of the two linear edges it should print an angle.
For the _DimAngle command, i would have expected to have the angular dimension drawn in the plane defined by the 3 points picked with the _Points option instead of the world xy plane.
_
c.
I don’t know… I get what you’re after here and it makes sense in a way, but in general Rhino dims are only CPlane based. (I do not see that it is using World, here, but current CPlane…?)
As far as I can see this one works (V6&7…)
Hi @Pascal, if you set the CPlane as shown in my image above, then use _DimAngle and pick the the first line (polysurface edge), do you see that nothing happens and it keeps asking for first line ?
_
c.
Hi Clement - OK, I see DimAngle not working there - yes…but Points works… are we on the same page?
https://mcneel.myjetbrains.com/youtrack/issue/RH-56812
Hi Pascal, i see _Angle _TwoObjects and _DimAngle _Points both fail in V6. Using _Angle command, there is no angle printed when picking the edges as sub-objects after choosing the _TwoObjects option:
Using the _DimAngle and _Points option, the CPlane it draws the angular dimension in is parallel to world xy with the origin picked at the first point:
I can only draw the angular dimension properly if i set my CPlane as shown in above image. Imho, 3 Points define a plane, so why not use them or add a new option to the command to draw in the point’s plane ?
_
c.
weird - I get different results in both cases
an angle from Angle > TwoObects…
Command: Angle
TwoObjects
Angle = 33.564
(Edges Ctrl-Shift selected…)
and
Even when i set my CPlane as yours it does not print an angle here…tried to pick curves and polysurface edge…
_
c.
Hi Clement - have you tried in V7? My 6 is certainly newer than yours - not that I am aware of any changes that would affect this - but those changes would be in V7, presumably.
@clement - Here’s my test file…
DimAngle_SubObjects.3dm (2.2 MB)
Hi Pascal,
even with our file i get no angle printend on _Angle _TwoObjects after picking the red and blue curve. If i use _SimplifyCrv on them, it works. (6.22.20028.13281, 28.01.2020) on Win7
_Dim_Angle creates a dimension using the _Points option.
_
c.
